Replacement for DAV-S800 Compact AV System
golfgirl
I have had the DAV-S800 system for almost 20 years - great system BUT the CD tray mechanism has become a bit sticky and I fear that it will soon be unusable. What I would like to do is replace the box with an updated model, but keep the 5:1 speaker system as it is. I want to still be able to play my SACDs on it so sound quality is important. Can anyone help point me in the right direction? Things seem to have changed so much now and I'm not quite sure what it is that I need!
1 REPLY 1
EdwinaU
Hi Golfgirl,
Welcome to the community.
Either a home theatre system or a Blu-Ray/DVD player may suit your needs. You can browse through some products here.
Tip: tick the Compare button on products to view their specification side by side.
Best wishes,
Ed
