SA-RS3S again
profile.country.SE.title
50nWyToMe
SA-RS3S again
 Hi , i wonder if i can connect SA-RS3S to the S2000 sound Bar ?   ( the Sub SA-SW3 worked it out )
50nWyToMe
2 REPLIES 2
LightFoot
Specialist
Hi @50nWyToMe
The question I would be asking is can a 3.1ch soundbar turn into a 5.1ch soundbar to benefit from adding rear speakers. I suspect not, as it only has a 3.1ch amplifier.
To answer your question, yes, according to the HT-S2000 product page. You need to expand Optional Speakers.
https://www.sony.co.uk/home-theatre-sound-bars/products/ht-s2000/related-products
50nWyToMe
