SACD playback via HT-NT5
frelunn
Can anyone help please
I have purchased an HT-NT5 soundbar to replace my old soundbase. The settings are all correct for outputs but I not get any sound playback when I play SACD via my UHP-H1,
if I play any cd music plays fine,
if I play any blu ray the disc audio plays perfect but no audio will be played if it's SACD OR DVD AUDIO everything worked perfectly with my old system. It's driving crazy.
frelunn
Thanks for your help my friend I must say with the system having the hi-res badge I thought it would be capable I'm very disappointed
Thank you for your help once again
3 REPLIES 3
EdwinaU
Hi frelunn,
Thanks for your message. We will take a look into this and someone will get back to you as soon as possible.
Best wishes,
EdwinaU
cass_n
Hi @frelunn - I checked this for you and your soundbar does not support SACD or DVD-Audio I'm afraid (see the bottom of p71 in the manual here).
frelunn
