Sony bdvn 7200w surround sound system
martoony
I have just bought the above item second hand but the bottom(stand) part of the tall sat speakers are missing.Anyone know where i can get hold of some?
6 REPLIES 6
Bat_Rick
Hi Martoony,
Did a little search on google, couldn't find any speakers sold separately.
martoony
I dont need the speakers.I need the base of the speakers that are the stands. A round plastic base that push on to the bottom of the speakers.
Bat_Rick
Hi Martoony,
You can use the link mentioned by Mariano and ask EET about this part, they will most likely refer you to another seller to buy the piece from.
martoony
Thanks. I will have a look
Bat_Rick
No worries!
