Hi all, advice/help please, which soundbar would be comparable with my TV? Model KD55XF9005
One to fit in-between the TV legs would be preferable
Thanks
Hello @Adeyfred,
the Sony HT-X9000F soundbar is designed to fit between your TVs legs.
It is the TV features on the product site: https://www.sony.com/electronics/sound-bars/ht-x9000f
Therefore I am confident to say, that it is fully compatible to your TV.
- Nic
Hello @Adeyfred,
- Nic
Thank you sir
Priced this one up today 👍
Thank you IamNic!
