Soundbar
Soundbar
When I first turn on sound bar it works for 5 mins then no sound comes out. But it works ok via Bluetooth via my phone. ???
3 REPLIES 3
My sound bar will work for the first 5 minutes then stops. The power stays on and will work with Bluetooth via my phone only. ???
No idea what doesn't work - some details would be helpful.
Cable quality matters - use high quality cables.
Joe_Dohn
Specialist
What is the model number for this sound bar and what is it connected to? What are you trying to play? What do you mean by stops, does it turn off, switches inputs or restarts?
