I have first and seconf model of the UBP-X800 and have an issue with both: if I shut down the player while a disk is paused, it doesn't remember where I was in the movie when I turn on the machine again.
I have had other brands earlier, and they even remembered what I was watching even if I ejected the disk and played another movie.
Any tricks/ hints/ settings I could try?
Thanks!
Hello @AudunSt,
but that is probably from the troubleshooting/issues part of the manual.
To me it says "if the resume function doesn't work" (confirming it is a feature like I described above) it can have these reasons.
So simply try to press "Stop" on the remote before switching the player off. It remembers multiple movies as well, but I can't give you the number of movies.
- Nic
Found it deep in the manual: these units doesn't have this feature. There should be space in the settings memory, but Sony have not found it important enough. Odd, as a small 30£ player from grosery store did have this feature.
Hi @AudunSt,
where in the manual did you read that? I'm asking, as it (I use the UBP-X800) is definetly a feature, but for some discs, you have to press "Stop" before shutting the player off.
I can resume 98% of the movies in my collection (I have around 200 Blu-Rays, mixed between 160 HD and 40 UHD Blu-Rays, so I have quiet the sample-size).
- Nic
approx page 30 in the Norwegian manual I found "Playback does not start from the resume point where you last stopped playback. • The resume point may have been removed from memory, depending on the disc when – you open the disc tray. – disconnect the USB device. – you're playing other content. – you turn off the player." This is a Q&D translation by me...
Hello @AudunSt,
- Nic
Usually, I put the film on hold before I shut down the player - stop film do really kick of the resume function.
