Machine works fine, with expception on some DVDs, after selecting the langauge the machine freezes and needs to be unplugged to resolve. Had my machine replaced for brand new one and does exactly the same thing on the same discs (mainly Disney DVDs).
Anyone experienced this or know of a fix or setting that may help?
Many thanks
Hi @Nick205,
Are you running the latest firmware?
Can you also please share exactly which movies you're having issues with?
Cheers,
Cass
Hi
Yes, I'm running the latest firmware. Specific DVDs (Disney) are:
Brave
Little Mermaid
Moana
Thanks @Nick205. Your feedback has been forwarded to the engineers for further investigation.
Cheers,
Cass
Hi again @Nick205,
Just a couple more questions for you to help our engineers look into this further:
Thanks,
Cass
Apologies for opening an old thread but I have seen this a couple of times, running latest firmware - was there a solution to this in the firmware or setting please? Peter
