Will 2.5mm speaker cable work with Sony STR-DH790?
SonyUserAC00101
I wanted to ask if a 2.5mm speaker cable will work with STR-DH790.
Thanks in advance..
SonyUserAC00101
AVR just arrived.. The 2.5mm speaker cables required a bit of patience to get them installed. For future reference for anyone else thinking of using 2.5mm cable best to get a smaller size as 2.5mm is the absolute max and doesn't make for the easiest install.. But as I had already run the cable I had to work with it..
Just waiting for the Sub to arrive now and then I'll power it up.
Fingers crossed it all works out!
4 REPLIES 4
Hi SonyUserAC00101,
Yes, should work without any issue.
Peter
SonyUserAC00101
Awesome! Thank you..
My 1st AVR will be the Sony STR-DH790 and is arriving today.. I ran the 2.5mm speaker cable yesterday to my 5.1 speak setup and then had a thought what if the AVR can't take 2.5mm cable?
So thanks for putting my mind at ease..
Sent from Yahoo Mail on Android
SonyUserAC00101
SonyUserAC00101
Success!
Everything works!
Watching Ant-Man with my son now and wow! To have an amp that properly decodes 5.1 Dolby surround encodings is next level!
Very happy with the Sony STR - DH790
