Touch screen freezing and unresponsive
RuntyBIGFOOT
Over the last week or so my L4 has developed a touchscreen problem it will freeze and become unresponsive untill I lock it and unlock it it is starting to happen more often now can anyone help me resolve this issue thank you
19 REPLIES 19
Gregz77
Mine does this, how can I repair ?
Piscie
Hey @Gregz77, I'd recommend following the steps here first before sending the device off to be repaired
Dicksy
Had the first phone delivered from BT no ringtone so was sent a replacement after 3 months of owning screen cover on and cased it started to freeze phoned BT they told me to restart the phone this went on for 8 months on and off once out of the 12 month warranty told nothing they could do. Took it to EE for a mobile MOT they found multiple faults phoned BT again told they can't replace or repair without a factory reset would not recommend this phone. Previous Sony handsets were great this one nothing but trouble no ringtone and has frozen 5 times typing this.
StephenCBanks
Thank you for interesting post
pipsony
I experienced these symptoms. I cured it by disabling the fingerprint manager  and used Swipe screen lock instead.
XBTENG
Sony Xperia L4 mobile.Problem intermittant screen freeze and switching images.Have tried reset,latest updates,cache cleared,safe mode.
Anonymous
Not applicable
Hey,
Is the same thing happening in safe mode?
Did you try to do a factory reset or software repair by Xperia Companion?
tinac12345
My sony has been doing this for ages and types lots of rubbish, and opens up all kinds of tabs.  Very annoying!
HannahEd01
Hi tinac12345, what's the model number of your phone?
Also, try the steps below, work as a charm.
https://www.sony.co.uk/electronics/support/mobile-phones-tablets/articles/00232845
N3W-F4RUQ
Mine started to have these problems described here. Screen stops responding and then it starts scrolling and opening apps on its own like it's possessed. Turning the screen on and off offers a temporary solution. Factory reset was no use and inconvenience. I did have my phone 2 years 7 months maybe it's the end of it's life. My previous sonies lasted between 1.5-2 years before dying. I've had Xperia z, z1, z2, I think z3 as well, L2, L3, now L4.
