Missing Conversion app after factory reset..
dev123
After the factory reset the Unit Conversion app is missing from my phone.. I tried resetting many times..even tried software repaire using pc companion.But no use.Can anyone please tell where i can download the app..or can anybody upload the app..and give me the link
Tags (1)
goelaakash90
3 REPLIES 3
Rickard
Master
Do you mean our small app unit converter? You can download it from Google Play: https://play.google.com/store/apps/details?id=com.sony.smallapp.unit
goelaakash90
http://forum.xda-developers.com/xperia-u/themes-apps/app-sony-recorder-converter-apk-t2324820
Download the zip file and Extract.
You can find the file in System>app folder
dev123
Thanks Man..
