new notification
sp3457
new notification
I have already updated android version but why my update center shows....
profile.country.RO.title
_alexdon_
Update,it should not damage the software or data.
alexdon
6 REPLIES 6
Thommo
You probably have a small update fix - Many other devices have had a similar update including my Z1 and Z Ultra
_alexdon_
Either that or it might be a server error.
alexdon
sp3457
So what I'll do?
_alexdon_
alexdon
MVN
Same with me.
SaNjj
Same update came to my M dual. What are you doing Sony? Give us Kit Kat update.
