Sony Xperia M2 - Factory Reset
Ant212
I have gotten my phone unlocked and I was wondering if i factory resetted it would that cause the phone to be locked again to only one carrier?
Thommo
How was it unlocked - You can check if it would relock by dialing *#*#7378423#*#* then going to Service info then SIM lock and if it says [ ] some text then 0 then it has been factory sim unlocked if it says [x] some txt then a number from 0 to 5 then yes it will relock or in my experience it will relock
5 REPLIES 5
Thommo
Ant212
It says
[] Network    0
and the rest of the details are similar so does that mean it has been factory sim unlocked then
Thommo
Yes you should be able to perform a reset or update or even repair without it been relocked as those details are the same as mine - Normally using a serial key or network unlock key is a factory unlock where as some of these stalls claim to unlock your phone but have simply on some occasions modified the network code which is you did a factory reset would reset this code
Ant212
Great, thanks for your help.
Hdezjose
when i try to make my M2 led working, i did the full reset, back to factory setting, i formatted all the origenal pre installed photos,music and videos by accident, anyone know where i can download it all back?
all thoese photos,music and videos they already inside the phone from Sony
