weird symbol appeared
darkpie101
this symbol appeared and I have little to no memory of downloading this app or unidentified thing. Searched in downloaded. applications and find nothing similar to it. Help me and tell me wether it's dangerous or not and how to get rid of it
Rickard
Master
It's nothing dangerous. It's the icon showing that NFC is enabled. You can disable it under Settings -> More.
1 REPLY 1
Rickard
Master
