Arc S test code
nasfannasar
Arc S test code
I want to know the test code for Arc S.
Nabeel
Master
Can you pease elaborate ??
you mean service test code ?
*#*#7378423#*#*
3 REPLIES 3
Nabeel
Master
*#*#7378423#*#*
nasfannasar
That's the code I wanted. Thanks a lot Slightly_smiling_Face
The ambient light sensor is working well in that test. I've ICS 4.0.3 & it's not working there Slightly_frowning_Face
Uliwooly
try again use a flashlight on it it just takes a bit longer to work
