Has anyone had success using the AT&T go phone plan with Internet access - with the Ray? Specifically - I purchased a data plan to provide Internet access but can't get it to work. I can only get Internet access via WiFi (in which case the data-plan is not needed).
I found one post that described setting up the APN info for a similar phone - for AT&T - but it didn't work.
And AT&T wouldn't/couldn't provide support for this specific phone.
Hoping someone else has succeeded.
I don't see why it shouldn't work
settings -> wireless & networks -> mobile networks -> access point names -> MENU -> add New
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Username:[email protected]
Password:CINGULAR1
Server: leave blank
MMSC: http://mmsc.cingular.com
MMS Proxy: wireless.cingular.com
MMS Port: 80
MCC:310
MNC:410
APN Type: leave blank
MENU -> Save
I'm pretty sure the Go Phone SIM you get is tied to the GO Phone, so putting it in another device won't work.
Bob H
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Password:CINGULAR1
Server: leave blank
MMS Port: 80
MCC:310
MNC:410
MENU -> Save
SkippyV here. I couldn't log back in and for some reason I couldn't get the password reset to work. It appears to work but nothing gets sent to my email. Even though responses to my original post succeed in getting to my email. Go figure.
So I made a new gmail account.
Moderator, please check this question as answered by uliwooly (I'm assuming I can't do that logged in as a different user then the OP).
Uliwooly, thanks for the info!
It worked. A few of my entries were off from what you posted. I'm now happily using my data plan/Internet with my Go Phone/Xperia Ray.
SkippyV (alias SkippyV2)
As per your request .... Done!
Marked Uli's answer as correct.
I'm glad it worked
