tranfering music videos to my phone by dragging and dropping is taking way too long..what must i do?
That doesn't sound right, try a different computer also try this
on your computer right click the file -> copy -> paste on the same folder -> right click the copy -> cut -> paste it on your Xperia S's internal memory
does your computer has USB 2.0 or above? are they large files?
yh it has 2.0 USB and the files are not large , roughly 90mb
How long do they take to transfer? does it take the same with other computers? are you using media go or just directly to the Xperia S internal memory?
its taking almost an hour just for one video....i really havent tried with any other computer to be frank...im copying straight to Xperia S internal memory
thanks a lot for your help mate, its way faster now...only taking a minute after i follow your intructions in the last message...thank you
Anytime
