Crashed Xperia S
klay79
Crashed Xperia S
I'm seeking your help/ advise for how to repair my crahsed Xperia S , my phone had already received the JB update that ends with 200, a week ago and it was running smoothly,
Just yesterday i was trying to run 2 application COPILOT for navigation and iheart radio, and suddenly it crashed , and the phone wont be able to run the operation system, it keep loading (its already loading the OS since half hour).
is there away to repair my phone using the PCC or SUS , i have connected my phone while its loading to PCC hoping that PCC would recognize but its not.
I just hate to send my phone to service center , hope to have your help very soon .
Regards,
Vengeance66
You should try with SUS, since PCC will just reinstall the same, and SUS will install fresh new copy.
If your phone is not recognized try installing the drivers manually from http://developer.sonymobile.com/downloads/drivers/
Cheers ๐Ÿ™‚
1 REPLY 1
Vengeance66
Cheers ๐Ÿ™‚
