Hi there,
I've a problrm while updating my neo to ICS.
Whenever I start the update, an error message appears while preparing the computer for software update.
Here's the message::
I hope you can help me..
Thanks in advance..
try using SUS instead
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Don't forget to check this
Sony Mobile fb click if you want the announcement sooner
http://talk.sonymobile.com/message/214765#214765
and once you get ICS
Xperia S Music App 4.0.4 leaked, does it work with your Xperia?
http://talk.sonymobile.com/thread/38259
Thanks,, that was quick & helpful..
My phone is updated now & I'm checking the new operating system ^^
I'm glad you got ICS, how do you like it so far?
Overall, It's quiet lovable..
liked the SONY logo on the start..
I also liked speed dial..
I downloaded Walkman, but it doesn't recognize the albums,, which is really annoying me
And the slide unlock doesn't appear..
These are the only problems I've encountered up until now..
don't use a pin lock, Google Music it's a great app too
