Help, 6.0.A.3.75 Xperia S Update
KarloGaderel
Hi, Anyone here encountered the same thing as mine?, ive updated my Xperia S into its 6.0.A.3.75 firmware and noticed this on my Sony PC Companion:
its Sated Here that my phone is "Sony Xperia S (LT26)"
but actually in my phone at the phone Information Section i have this:
Model number LT26i, is this thing normal or i just f*cked up my phone?...
hoping you guys could tell me more about this, thanks....
Uliwooly
PCC and SUS just got updated so that could explain why, but don't take my word for it, visit this
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
3 REPLIES 3
Uliwooly
the code name for the phone is LT26i, but at the sony mobile website, PCC and SUS it will only have it as LT26i, Sony and Sony Ericsson phones prior to 2012 they had the i (international) and a (american) versions, but now the i are both international and american versions in one version, and it will be pointless to put both labels a & i if it's the same phone the only difference (for the most part) the 3G antenna/frequencies its compatible
in other words, no you didn't damaged your phone
KarloGaderel
thanks man, but i've noticed it before updating it into 6.0.A.3.75 from 6.0.A.3.73 my PC Companion Shows that I have LT26i not until I update it..that's why it troubles me somehow,,,
Uliwooly
