Help, having some problems setting up the email.
luis_DR
Can anyone help with this, i try to setup the email. and this shows up:
HELP PLEASE.
Uliwooly
btw the email app preloaded it's quite basic, you should look into K9 or Maildroid
4 REPLIES 4
Uliwooly
you have to be more specific as there are different settings that you have to enter for each email account, you can googe: server settings android "email account"
Uliwooly
luis_DR
Thanks, I downloaded the K9 mail. set it up in 30 secs.  Slightly_smiling_Face
Uliwooly
Anytime Slightly_smiling_Face
