I've tried to update the phone to v6.0 and before i finished the update the phone stoped from responding and know it's not working at all, no power, can't connect to PC companion. If the software is damaged, is there any solution? How can I restore it or repair it? Please advise.
No power ?
Leave it to charge for sometime
Or first try-
Press and hold Power Button and Volume Up button at the same time
5 Seconds > Restart Phone
10 Seconds > Shutdown Phone
If that doesn't helps then
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
No power ?
Or first try-
or
Thank you...My Xperia S is back to life!
