Unable To Update Version 6.0.A.3.75
Not applicable
hi when i plug phone (Xperia S) into laptop its says theres a update available (sony pc companion) when i try and update it fails its says unable to install or start  software components,ive tryed disabling my firewall/antivirus and still doesnt work,when i check for a update on my phone its says im up to date,is there a pc only update?
gwhispererz
Champion
Hi, suggest you update phone with Update Service. Here's the download link, http://www.sonymobile.com/gb/tools/update-service/
3 REPLIES 3
gwhispererz
Champion
Not applicable
works great thank you
where can i find the change log for this new update?
gwhispererz
Champion
No problem ....
No idea regarding the change log.
