Please inform of a good software that i can use to BACKUP my
before reparing my ICS 4.0.4 RAY
Tnx in advance!!
http://www.fjsoft.at/en/downloads.php You can also use My Phone Explorer, ideal for backing up sms and contacts.
Hi, have a look at MyBackup in Google Play.
Hi!,
I think that Mybackups cannot backup data ON PC. Is there any software that can be use to BACKUP data in into PC...
I used a software back when i was using my K750 and K800
to backup all my contacts & SMS to the PC. Surelly there must be a one to use on ANDROIDs..
Can it backup into PC???
No, it can't. MyBackup app can only backup to online servers and SD card.
Yes, that link is for the PC version.Once you've backed up your sms and contacts and updated your phone, you can then use it to transfer both back to the phone.
Thanx I'll try on this
No problem. Just remember that My Phone Explorer can only read sms from phone memory, whereas contacts can be read from both phone and SIM card memory.
Thats all i need..
Hey, this is the software that i used with my previous mobiles!!!
Got me the JOB DONE, THNAX!!! :smileygrin:
