Laging Problem :/
Shahzaibalizakr
Laging Problem :/
Hey, I have been experiencing laging issues from last few days in my Arc S πŸ˜•
Contacts take about 5 to 8 secs to open up, and same is the case with the dial pad πŸ˜•
Got ICS 4.0.3
Please HELP!!
Uliwooly
that's never a good idea, taskillers, antivirus and battery deffenders will slow down your phone, and also create issues with other apps and network connectivity
the lag won't go away unless you downgrade to 2.3.4
16 REPLIES 16
Uliwooly
once you get 4.0.4 the lag will not be as bad, in the mean time, clear your call logs from your dialer or you can use Dialer One
Uliwooly
if you don't want to wait for the update
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
Shahzaibalizakr
Dialer One is an app?
Uliwooly
yes, its an app, check the market
Shahzaibalizakr
I dont wanna do manually update, literary bad at all those technical things. Any other solution? Does stoping the background app helps?
Shahzaibalizakr
No solutions for the orignal dialer, dont want to delete my logs πŸ˜•
Uliwooly
stopping background apps don't help that much, but using a third party app like dialer one will help.
Shahzaibalizakr
What about using a application kill app? Will it be useful in laging thing?
Uliwooly
