Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
June 2010
June 2010
Is it possible to customize the message tone on the W760 like you can the ring tone, or are you stuck with the 8 or so canned sounds that S/E provides?
Thanks in advance,
Sean
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2010
June 2010
If you go to settings then sounds and alerts then down to message alert you will see you can replace one of th alerts with your own sound.
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2010
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2010
June 2010
Perfect - worked like a charm! Thanks, mate.
Sean
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2010
June 2010
Glad I could help.
