music player...
ahmadfaiz
music player...
hello there..
can anyone tell me where i can get xperia s music player + the equalizer and all the stuff for my XMP??
thanks.. Slightly_smiling_Face
Nabeel
Master
19 REPLIES 19
Nabeel
Master
Are you on ICS ?
iF YES THEN here you go
http://forum.xda-developers.com/showthread.php?t=1676013
ahmadfaiz
yeah,,im on ics..i've tried this one but i cant find the equalizer...
and for the additional file,where do i put them??do i need to root my phone??
thnks..
Nabeel
Master
Aren't you able to install soundenhancement.apk ?
ahmadfaiz
yes i can but when i try it by using earphone while listening to music the sound enhancer doesn;t seems to be working@no effect..hmm....how bout the th other files?where shoulf i put them???
Thank you..
Nabeel
Master
you will have to root if you wan't to place the additional files
ahmadfaiz
hmm..i dont wanna root my phone..because im afraid that my phone will brick..is there some other way to solve this problem?
Nabeel
Master
Nopes, the additional files are system files, and you can't replace system files until you root
ahmadfaiz
okayh..does soundenhancer.apk really works??because i cant hear the differences when changing genre...please help..
thank you..
Nabeel
Master
Oh yess, i have installed it, it works really good Slightly_smiling_Face
