hello there..
can anyone tell me where i can get xperia s music player + the equalizer and all the stuff for my XMP??
thanks..
okay..i will try it again after this..thanx nabeel
what is the function of the additional files? do I really need to use them?
If you wan't all the extra functions,, for example equaliser
If you just wan't the music player then only the apk is enough
well I installed soundenhancer.apk and I got the equalizer, but what are the other files functions?
and is it possible if I want to uninstall this music player?
Other functions are changing background colours
Yes you can uninstall it anytime, settings > applications > all > walkman player > uninstall updates
can u tell me where to put the files???and rooting is required right?
Rooting is required,
if you root then i will make it easier for you..
after rooting, install CWM XPERIA From android market and then install this http://forum.xda-developers.com/showthread.php?t=1681256
can we just do that without rooting? hehe
anyway, will Sony release the update of the music player for the ICS phones?
im not sure on rooting my phone because im a newbie on this and im afraid i'll brick my phone..
Someone have the original music player installer? Installed walkman but mine isnt rooted, so no equalizer 😕
