My C510 starts but freezes after selecting normal mode from flight mode select menu
No Escape... I pulled off battery and restarted many times... no escape
I tried sony update service...but no use
because phone stucks at first, does not show the menu for usb connection mode when i connect usb, so cannot select phone mode
Please help
What i want to do?
Did you try using the update service via PC with the phone switched off?
Yes friend..
But its mass storage mode only.....
Try rebooting the PC with the phone connected and see if that helps.
Ok.. thanks
I will try your suggestion
you mean updating with pressing and holdind 'c' button , right?????
Yes.
Sorry Dr_Chris....
No escape....
Sorry Dr_Chris....
No escape....
Take the battery out, replace it and try again.Otherwise, you will need to contact a repair centre.
Ok Friend...
But that not helps... I already tried it many times....no escape
If no other ways means ... i will contact service centre
Bcoz my phone is out of warranty.. bought 2.6 years ago..(approx)
