New Android update
Vishnu_Nair
New Android update
My PC Companion showing an update and when updating, it stops at the end of prepare bar and not moving further....and in phone no update is showing while using wifi also...........
Nabeel
Master
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
4 REPLIES 4
Nabeel
Master
                  or
Vishnu_Nair
but,pc companion dont work.??
Nabeel
Master
This is not pc companion
Use the above link to update your phone
Vishnu_Nair
ok dude........i started downloading this SUS........hope it will work...thanks........
