- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Please anyone help me with this I have a Xperia X10i which my father bought from overseas the phone is just fine evryway but recently i got to know that there should be an Application Matrket tab which is missing in my X10.Now as I bought it from overseas I can't just go and ask the dealer for help..Please someone help me with it I can't install any applictions in my phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The Android Market is location sensitive and I would imagine that it was bought in a country that does not allow it.
There are a couple of things you could do, the first is to debrand your phone and install a local version of the firmware, for example if you are in the UK you can install the generic UK firmware. This site isn't necessarily the right place to source that kind of information, can I suggest you have a look over at XDA Developers or Android Forums and research debranding your phone. If you are going to undertake this I recommend you get as much information together as possible. You will see warnings about it voiding your warranty but the warranty does seem only to bind to the country of purchase unless bought within the EU.
You could also try apps on your phone using the browswer, either www.getjar.com or have a look at this site http://slideme.org/sam, the app count is not as high as the Android Market but you can cover most bases with apps from these sites.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for help Suze that works for me with Sam and Getjer..I guess I have no other option for now without these 2 sites.Thanks again.
