hay ,i can't access the notification bar in the lock screen ,as it is instructed in the video (the one on the ics sonyericsson page) ,i can only pause and play songs in the lock screen ,is it because i am using the face unlock feature ?
Yes....
If you use any type of screen lock or when your mobile is in flight mode, you can't access notification bar from locked screen
then what is the purpse if the lock screen if it isn't locked ?
I am sorry ,
Means ??
you mean i can't use the notification screen in the lock screen ,if i have some kind of lock ..?
Very true
well it is called a lock screen ,if there isn't a lock on it ,then it is useless .but thanx for helping
It will only work with slide to unlock or no lock
You yourself think, you have had set a lock ( face unlock) due to privacy reasons so that no person other than you could access your mobile.
Now someone sends you a message. If the notification bar is accessible even after putting a screen lock ( means any person other than you could drag it down to see the notification without unlocking it ? ) then what's the use of screen lock if anyone could access your notifications ?
Did you get my point ?
I didn't revise what i wrote above , so ignore my mistakes
hahahahaha this is true ,haha ,well you got a big point there haha ,like a boss
