I recently updated my Xperia arc (LT15i) to ICS 4.0.4.
There is a new app added by Sony, the Performance Assistant. Only 3 apps appear in the list -
1.McAfee
2.ANT+
3.Facebook inside Xperia
I wanted to disable Facebook as well. Is it possible to add Facebook to Performance Assistant's list in order to disable it?
How can I add more apps to that list?
Thanks!
Vikram
Try this way
settings > applications > facebook > uninstall updates ( if this option is not there then select disable )
There is an option to 'uninstall updates', but that would just, kind of downgrade facebook. It won't disable it.
Is there a way I can completely disable the apps that I do not require?
Is there any limit to applications that can be disabled using Performance Assistant? btw, I have LWW.
