Pre-loaded games
tezlewis1988
Pre-loaded games
Hi, i have brought a new xperia play from amazon, it came with ice creme sandwich 4.0.3, it hasnt got any pre loaded games, i was wondering how do i get the games, as it comes with crash bandicoot and a few others.
thank you in advance
Uliwooly
this should work just fine
http://forum.xda-developers.com/showthread.php?t=1324703
37 REPLIES 37
Uliwooly
that doesn't seem that it's true, the Xperia Play won't get ICS
Uliwooly
is this phone new or used, if its used the only way it got ICS, is with a Custom ROM, go to settings -> about phone -> check Android Version and Build Number, to get new games, buy them at the Play store.
tezlewis1988
Sorry i am a newbie when it comes to smartphones as its my first phone, i brought it used
but before i brought it i read you get a few games crash, fifa 10, bruce lee
it says android version 4.0.3 build number 4.1.h.0.4
Uliwooly
on the homescreen -> press Menu -> settings -> about phone -> check android version and build number
tezlewis1988
thanks for ur help
Uliwooly
Indeed it has a custom ROM
tezlewis1988
What does that mean, can i get the preinstalled games?
Also what would you suggest, can you go back to normal version?
i don't seem to be having any problems apart from it came with no games? i have brought some of the app market but none are playstation games.
Uliwooly
yes you can go back to 2.3.4
Xperia Play 2.3.4 minor update 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/29378
if your ICS is stable just keep it. and buy the games from the PS store
tezlewis1988
Thanks again i would like to keep it, can i have the link for PS store is that where i can get the playstation games?
