Pre-loaded games
tezlewis1988
Pre-loaded games
Hi, i have brought a new xperia play from amazon, it came with ice creme sandwich 4.0.3, it hasnt got any pre loaded games, i was wondering how do i get the games, as it comes with crash bandicoot and a few others.
thank you in advance
37 REPLIES 37
Uliwooly
this should work just fine
http://forum.xda-developers.com/showthread.php?t=1324703
Uliwooly
or even this
http://forum.xda-developers.com/showthread.php?t=1134334
tezlewis1988
I have tried the following. now i am just getting a vibrating sound and black blank screen?
17/021/2012 23:21:56 - INFO - Flashing loader
17/021/2012 23:21:58 - INFO - PROT_VER="03";DATE="20110217";TIME="15:47:00";VER="R4A066";CXC="1234-5769";TYPE="S1_LOADER";UNIQUE_DEV_ID="6E6745DC12B43B880230AE34C8C93D9E11AFF276";SEC_LOCK_STATUS="LOCKED";OTP_DATA="4B6D7100471404C81504042800C4C73FB001002000000000";IMEI="35730204208777";AID_VERSION="0004";EROM_AID="0001";LOADER_AID="0001";SW_AID="0001";CUST_AID="0001";SIM_LOCK_AID="0001";HWCONF_AID="0001";PROD_ID="0001";ACTIVE_LOADER_AID="0001";MEMDEVS="02:00:002C:00B3:0000:00002000:00020000:00000800:00000040,03:03:0003:5344:0080:0001D9C0:00010000:00000200";MAN_ID="002C";DEV_ID="00B3";SIN_VER="0001";AID_TAMP="NOT_TAMPERED";MAX_PKT_SZ="00010000";AUTH_LEVEL="NONE";AUTH_MET="0001";CARD_PRESENT="YES";CARD_SIZE="8GB";LOADER_ROOT="S1_Loader_Root_773f";EROM_ROOT="S1_EROM_Root_d601";SW_ROOT="S1_SW_Root_883f";CUST_ROOT="S1_Cust_Root_9603";SIM_LOCK_ROOT="S1_SL_Root_c422";HW_CONF_ROOT="S1_HWConf_Root_08af";BIM_STATE="DISABLED";�
17/021/2012 23:21:59 - INFO - Flashing preset
17/021/2012 23:21:59 - INFO - TA value : [00, 00, 08, B2, 00, 00, 00, 02, 00, 00, ]
17/021/2012 23:21:59 - INFO - Flashing finished.
17/021/2012 23:21:59 - INFO - Now unplug the device and power it on
17/021/2012 23:21:59 - INFO - Then go to application settings
17/021/2012 23:21:59 - INFO - turn on Unknown Sources and Debugging
It wont even boot up now Slightly_frowning_Face
tezlewis1988
so gutted now, all i want is stock
the message i get through pc companion 'there is no software update available'
Maybe i forgot do i need to now flash the firmwire? because pc companion wont let me repair, also do u think my bootloader is now locked by the above post?
Do i now take 'Xperia_Relock_bootloader ftf' out of firmwire and put in the stock firmwire, or do i put them both in?
Uliwooly
try flashtool once more
tezlewis1988
thank you for you're help, i got it working on gingerbread Slightly_smiling_Face
it just wouldnt do it through pc companion, i had to download the firmwire and flash it, first time i'v flashed anything on my play, glad it worked.
Uliwooly
I'm glad I could help Slightly_smiling_Face Enjoy
Uliwooly
here are some apps taht you can use on your Play
http://talk.sonymobile.com/message/164329#164329
