There are some errors after the update Such as:
I want to root it now how ?
See How to root 4.0.4 part here
{GUIDE} Install ICS ( Ice Cream Sandwich) on Xperia™ Smartphones, Root and Downgrade to Gingerbread
Hi there.
I would suggest you to format your SD card and reinstall ICS as follows
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC or SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
ok i'll do
but how to root my phone ? in ICS 4.04
can do this ?
my xperia arc lt15i with ICS 4.0.4 update in 6-6-2012
dear Nabeel (are you arabic ?)
thanks to your fast reply ^_^
i'm stop in this step:
i don't have 4.0.3 firmware
where can i do to download it?
( it is this ?
| Arc (Lt15) | 4.1.B.0.431 |
i cann't download from uploaded.to
Nopes, not from Arab but India :smileygrin:
Nopes this is 4.0.4
download from here
4.0.3
http://www.4shared.com/file/9x8Kx7cG/LT18_41A0562_Nordic.html
or
http://www.4shared.com/rar/5iUkOeC0/LT18i_41A0562_Generic.html
Tired with me:smileyblush:
Welcome to you from any country:smileylove:
i'll download this http://www.4shared.com/file/9x8Kx7cG/LT18_41A0562_Nordic.html
but it's for lt18 Normally do not cause problems ?:smileyalert:
my Device lt15i (arc not arc S )
No problem
You just have to flash the kernel, it's the same
after you flash 4.0.3 kernel, root your arc, after rooting download 4.0.4 rom for arc ( not arc s ) and flash 4.0.4 kernel back
