problem in updating
Not applicable
problem in updating
hi, im having a problem on updating my phone (Xperia ray), i tried to update it using pc companion., but its not successful, it is already in number 3(update), then it suddenly stop and said that there was problem occured, i unplug the cable and try to open it, but it did not open, please help me.. please
Uliwooly
or use Flashtool to fix it
Xperia Ray ST18i/a 2.3.4 update 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/30948
18 REPLIES 18
Nabeel
Master
Update via
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
both the links are same
Not applicable
thank you.. i'll try it, i hope it will work..hays
Nabeel
Master
do tell the results buddy Slightly_smiling_Face
Not applicable
can i ask another question?..how can i restore it old setting if the update will not be successful?
Nabeel
Master
if update would be successful or unsuccessful, in both the cases, settings would remain unchanged
the settings at present would remain as it is ( both cases)
Not applicable
i think my phone has been corrupted..what should i do now?please help me..:smileysad:
Uliwooly
can you elaborate?
do you see a exclamation mark inside a yellow triangle? if that's so just use SUS and repair it
Uliwooly
Nabeel
Master
corrupt ?
what happened ?, when happened ?, what did you do? please elaborate
again use SUS or flashtool (link by uliwooly)
but this time you may loose all settings and phone data .
