- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I bought xperia mini pro a day ago.
Everything is fine. But sometimes seems that the phone can't awake from sleep. I hit power button keyboards and 2 touch screen keys are highlighted but display stays blak. Only removing battery helps me. What does happen?
I didn't find in manual how can I do forced reboot. I mean "press somrthing like Home and Power button together during 5 sec" and deveice will reboot automaticaly as a result. Because when I have a black screen I can't reboot device using usaul way. Can you help me?
Thanks for answers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, check if you can get a replacement since you just got it a day ago.
Other than that, you could try repairing phone software with Update Service. Here's the download link, http://www.sonymobile.com/gb/tools/update-service/. Download and install to PC/Laptop, launch it and follow on-screen instructions. Be aware that this will erase phone data completely.
- Thread moved to correct community -
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May be you know how can I do 'forced reboot'? I have iPhone and I can press 'Home and Power' buttons together and keep it pressed about 5 sec then iPhone will reboot. Does the similar functionlity exist for SE xperia mini pro?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you can with the 2010 and 2011 xperias but you can remove the battery
with the 2012 Xperias you have to press and hold power + volume down
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Nope, not with Xperia Mini Pro ....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I gave the device to a service center. The new issue appeared: device lost internet connection on wifi after 20-30 min using. When I pressed turn wifi off in the settings it became active again and then device tried to restart automatically. But stopped on XPERIA logo.
Seems that I bought defective device
Thanks everybody
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are you having the new issue with a replacement or original set?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Original set. In Belarus it is not easy to replace the device. Based on conclusion from service center the seller should replace the device or refit money.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Software repair phone again ....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
With the same problemi (black screen when receiving a call without the possibility to open the conversazione through any button hit /screen touches) i didn't solve the problem neither through the soft/hard reset through combinaton of volume/power buttons. The problem was due to the trasparent skin conflicting with the light sensori on the top left of the screen. Once i cleaned it i solved.
