Software update 6.0.B.3.184
РЕШЕНО
Andrewas
Посетитель
Is the latest software update available worldwide because when I connect my phone on  PCC it says that it is up to date but in my phone's settings it is 6.0.B.1.564
Thanks in advance!
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
Bardia
Посетитель
I suggest you wait for ICS.maybe they remove .184.it comes soon Slightly_smiling_Face
15 ОТВЕТ 15
Andrewas
Посетитель
Anyone?
sherif
Посетитель
update it from the update center through wifi
dont use pc it has many bugs
Andrewas
Посетитель
I've tried a thousand times through the update center and it still says that i have the latest software installed!
Andrewas
Посетитель
Anyone from the support team?
Неприменимо
Andrewas
Посетитель
The same thing! AGAIN! Software up to date! But it's still 6.0.B.1.564!
Bardia
Посетитель
Andrewas
Посетитель
I guess that's the only choice...:smileyplain:
Bardia
Посетитель
it's better for you,because .184 has alot of bugs like wifi problems,network problems and etc for some users Slightly_smiling_Face
