hi , when can i see tv-live programs on my new Xperia-S.I installed Sopcast on my phone , but didn"t work ?!?!?!?!
The phone does support streaming. Your connection might however not support it.
If you connect with WiFi, check so the router support RTSP (real time streaming protocol).
If you connect using the operator's network, make sure they allow this.
Also, try e.g. the YouTube app in the phone just to see if this works or not. If it does, then the problem is not with the phone or your connection but Sopcast.
What do you think about this forum? Let us know by doing this short survey.
