Good day!Can who encountered such a problem as long time the phone is enabled,the lock and nobody call you can't,and after a call or unlock knocked SMS saying that you now called,is there a solution to this problem? Wi-Fi is,can't open anything happens only with the third always attempts,4.0.4 version costs,depends on her??:smileycry:
Gelöst! Gehe zu Lösung.
Repair your phone with SUS or PCC > stay away from taskillers, antivirus, task managers, etc if that doesn't work get a new SIM card
Bridge (for Mac)
Bridge (for Mac)
OK, I'll try after the answer will tell
Do everything according to instructions,but in the paragraph where you have to press the volume down button, nothing happens,it's pretty weird.
You have to press and hold volume down > THEN > connect the usb cable while holding the volume down key > do not release the key
OK,now try
It turned out,many thanks for your patience))
Anytime
