tools icon showing at boot ?
Jeroen_
After updating to JB, i restarted the phone, uninstalled some apps that came with the update, and did a new reboot.  The Sony logo showed, but after that some kind of tools icon is showing, along with a blue progress indicator that doesn't change.
I can't find any information anywhere about this screen, does anybody know what's going on ?
dzadzev
Your phone is repairing the file system when it shows this screen, It might take several hours. You should connect a charger and wait, your phone should start up eventually.
6 REPLIES 6
Jeroen_
This is what's on the screen now:
http://i.imgur.com/GFRr8Cj.jpg?2
dzadzev
Jeroen_
Thank you, I went to sleep with the phone in the charger, and all seems ok now.  :smileyblush:
ayka
I'm experiencing a similar problem with my Sony Xperia SP, showing the same screen as the picture above. Last night I connected the charger hoping it would work again in the morning, but it's been like this for over 24 hours now and nothing's changed...
What do I do now? Slightly_frowning_Face
toollips
Yes
PIESIE
MY PHONE STUCK WITH WRENCH AND SPANNER
