Hello,
Yesterday i saw i had a text message and wanted to read it. When i slid to get lock of half way it stopped, flickered and got back in begin posistion.
Since then i cant use my touch screen. Battery removing and such doenst work. Cant do a repair cause cant use my touchscreen to get in required usb modus.... Any1 got somne ideas?
Regards,
Dennis
oops oops oops,, signifies a hardware issue,,
sad for you,,
give a last try using SUS if still not successful then you need to visit service center to get it done
all the best buddy
Update/Repair your phone via PCC OR SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
both the links are same
Am trying now
Cheers for the fast reply. I knew i could repair with pcc, but it just doesnt show when u have ur phone connected. I did already try SUS, but it asks me to get phone in usb connection mode or something, u just have to drag status bar etc etc... But that part is hard when ur touchscreen isnt working.
Regards,
Dennis
I did got it to update, but that wasnt the issue it seems. Still same probs, still cant use touchscreen.
Cheers for help though!
Regards,
Dennis
wait a minute , was software repair successful ?
for sus you don't need to drag any bar down.
did you install sus ?
after installing it on your computer, ( don't connect your mobile) open the application ( sus) select your phone and follow the steps
remember you need 50 % battery for it to work
I think i did it wrong with SUS. However thanks to ur reply earlier in this post i was able to do the update using PCC. When i booted phone after update for the first time there is a blue screen instead of my "own" picture background, and clock resetted. So i concluded it did update.
Still, didnt fix the touch problem though
Regards,
Dennis
Installing SUS as we speak... Errrr type
Yeah i think its a hardware issue aswell, but had to try. Weird though, it just stopped working... And i take good care of my phone
Second SE that breaks down with some vague error... Hoping i get more response from SE now though.
Cheers for the help Nabeel!
welcome Dennis
Do tell me once you get your phone repaired
