update help
Not applicable
update help
Help me, I cant update my xperia neo to android 4.0, pc companion always say that there was an error stufff, my current os is android 2.3.4 please help me T-T
Uliwooly
is your SI number on the list?
8 REPLIES 8
Uliwooly
Uliwooly
Not applicable
what is an si number?
Not applicable
wait, i'll try tnx 😃
Uliwooly
check this
http://talk.sonymobile.com/message/199355#199355
Uliwooly
let us know if you get it
if you do get it
Xperia S Music App 4.0.4 leaked, does it work with your Xperia?
http://talk.sonymobile.com/thread/38259
Not applicable
thank you very much for the help,, it worked! i now belong to the ice cram sandwich family 😃 I really appreciate it XD
Uliwooly
anytime, don't forget to check the Xperia S's music player
