Today I went to my local sony xperia shop to ask if they have spare for the waterproof back cover , apperntly they do not have one, and they don't know yet whent they would have it on stock, they told me to keep in touch just in case they have one available.
I don't know how it the waterproof back cover got scratched,is it part of normal wear and tear? my phone has its own pouch, and is kept from my separate pocket. and frankly, the ingress caused by the back cover is deep, I thought it was enough to protect the camera lens, it's very awfull! it really affects the camera quality drastically. here are some samples I made.
first image: without the waterproof back cover .
Second image: with waterproof back cover attached.
you have to go to a sony service center for and ask for a replacement. http://www.sonymobile.com/global-en/support/contact-us/
I also had this problem. In order to fix the problem, I just wiped the glass/plastic cover very hard until it removes the scratches. I also noticed that the semi-violet tint of the glass/plastic is also removed. Hope this helps. And please, notify me once you've purchased a new back cover. Thanks!
that what I did, but it doesn't remove it, yeah I notice it too. I have yet to receive my phone, I'll update you guys once I receive my phone.
Here you can buy a new battery cover for the phone. This is a Polish shop but they sent the cover to me to Ireland.
http://www.techgsm.com/Cover_Battery_Sony_Ericsson_ST17i_Xperia_Active_original_,141832.html
I got the same problem... I try to order it from poland... thanks for the link
