Is a screen guard necessary for the live with walkman.
My screen guard which was on the phone came out accidently and i was wondering how to fix it without bubbles appearing....
Pls tell whetther i can use the same screen guard or have to buy one to repel scratches.
I am from Sri Lanka and in shops i was asked to put a new scrren guard as the screen gets scratched whereas the phone has a scraych resistant mineral glass...
PLs help me....i dont want to scratch my screen
hi again Kevin , good to see you are regular here
First of all its totally your wish to have a screen guard, however it is not necessary, but advised to install to be on the safe sight
get it fixed at some shop, use the original one only
Ah thanks a lot...i was doubtful because i read about scratches users have encountered on other web sites.
BTW got a kingston 8GB, works fine
