HELP, i cant update my Android 2.3.4 to ICS! When the Download starts, it appears an error and the Download ends... π
what to do?!
It's due to overloaded servers.. you wll have to try after few days
Or try to use this
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
Or try to use this
or
