Xperia mini pro speaker problem
buzzlightyaa
Hi guys,
I think theres some problem in the loud speaker of my phone. I think its not as loud as it used to be. I went to the service center and they said the speakers are fine. I even did the service menu check with my speakers and i could hear everything. But i still dont know if my mini pro is as loud as the other mini pros. Theres this song in my phone which i cant hear properly. The songs link is - http://www.4shared.com/mp3/OT1U_IWz/07_Ari_Ari.html?
At around 0:08 a guy says something but I cant hear that on my phone, i mean i can hear it but the sound is too low.  And at around 0:20 another tune starts which is also not audible. I can hear that on my laptop and other phones but not on the mini pro. So can you please put that song on your mini pro and see if you can hear it?
Thanks alot,
Adi
m4dj
Ihear nothing at 08 or someone saying something. Thats not the point. I mean the whole track volume is ok. If you hear the track volume ok, then everything is ok. If you need to hear someone talking or saying something in the track, check some other track because this one is not a good example.
11 REPLIES 11
ahmadfaiz
have you try service test?? *#*#7378423#*#*
go to service test and select speaker..hope this help..
buzzlightyaa
I have done that but i still think its not as loud
m4dj
Why dont you upload on your phone something like a whole cd where you know that the sound volume is ok. If the mp3 is ok then the volume of the sound must be the same as for example your alarm or ringtone. Check also the volume (MEDIA VOLUME) in the menu. Also check the option "xLOUD" in the sound settings.
What I have noticed in my xperia mini is that the speaker volume when doing a conversation is very poor. I mean the external speaker is so weak compared to all my nokia phones from 10 years ago...   Thats so strange. When I listen to the music its seems fine.
buzzlightyaa
Yeah thats ok. But you would do me a great favour if you could just upload the song on your phone and then tell me about it. Thanks!:smileyhappy:
buzzlightyaa
Come on guys, help?
m4dj
Hi. I have just. Downloaded thos song directly to my phone. I did not li listen to whole ttack, but the volume of the song seems normal to me. T
he sound os normal.
buzzlightyaa
Hey bud,
See if you can hear a guy say something at 0:08 and if you can hear the tune that starts at around
0:20.
Thanks
m4dj
buzzlightyaa
And just do one last thing, put the speaker on your ear and then see if you can hear it. Please.
Thanks! Slightly_smiling_Face
