please guys help me. i just droped my Xperia P in water... plz help me what should i do now
i turned it off quickly after picking... its about one hour ago this happend to me
please help me i dont have money to buy it again
this is a great suggestion
remove the SIM card and SD card > get a plastic bag and fill it with raw rice and let it dry for 24 - 48 hours, replace the rice every few hours
bro what if i dont have rice at this time... :'( coz m in my hostel and its imposible now to get the rice
plz any other way... i have removed my sim card and turned it off ,,,
m gonna keep it off for 48 hours and will let it dry in the sunlight... lets see what happed
do pray for my phone
i would suggest uliwooly's advice as well! and try using a dryer it will get the water dried as well!
should i directly turn on my cell after keeping it off for 48 hours... or should i put it to charging first?
Please do tell us what happen next. Hope your phone will be fixed right away
i'm so much worried.. coz when it was dropped and i picked it up the secreen was blinking lil bit
lets hope for good... i,ll post about wat happened with my phone
