Hello, my Xperia S have a big problem with the connection at Pc Companion, it dosen't connect and the PC don't see che storage....
What I do?
if the USB it's connected does it recognize your phone? if it doesn't it problably needs the drivers, turn off your antivirus and firewall
then run SUS as if you were going to update your phone
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://talk.sonymobile.com/thread/36355
open your computer -> Xperia S
do you see it there?
No but after much tray it connects in WiFi mode. When it don't connect the pc don't see it
hold on, are you connecting it through wifi or usb cable?
Via USB mode and WiFi.
When I try at the last try I disconnect the USB and it connects automatically in WiFi mode...
